-   Sunsation (https://www.offshoreonly.com/forums/sunsation-43/)
-   -   single ski tow eye on rear of 288 (https://www.offshoreonly.com/forums/sunsation/107717-single-ski-tow-eye-rear-288-a.html)
Chris288 07-14-2005 01:17 PM
anybody do it ?? where did you put it ??? Took a look behind my H.O. and things look a bit flimsy uder there for the stress of a ski hook, plus there is the vent in the middle... ??????
Canada Jeff 07-14-2005 02:46 PM
Re: single ski tow eye on rear of 288
Maybe you can find on old arch off of a Sonic or somthing, make her into a wake board boat ;-)
DaveSunsation 07-14-2005 03:21 PM
Chris,
We put them on all the time, but first we bulk up the area where we put them with more glass and laminate in a 1/2 in piece of marine plywood. We put them on the starboard side of that center vent. Keep in mind, the cleats work real well, folks secure a line between the two cleats and center off that for pulling.
David
Chris288 07-15-2005 08:11 AM
Dave,, Thanks for cabin door stopper,,, and the advice.... :)
Swift1 07-15-2005 10:13 AM
Along the lines of what Dave mentioned, I purchased a waterski bridle this year to eliminate the offset of the stock ski eye. Basically a big "Y". Attaches to the rear cleats and hangs clear of the swim platform.
Check out Bart's or Ski Limited, costs about $30, works well.
KN 07-15-2005 12:44 PM
Hey Chris this is what I have, You can pull from just one, pull two skiers. or use a water ski bridle like Swift1 mentioned that works great. I would be hesitant about using your cleats, were they are reassessed you may get some chaffing. My cleats have also loosened up with regular use, and I cant get to them to tighten them up.
Kirk
...... Chris I cant post the pictures for whatever reason I will e-mail them to you. File is to large, and I don't know how to down size it.
Kirk
DaveSunsation 07-15-2005 01:28 PM
Kirk,
You should be able to reach the polly nuts in the back with a wrench and have someone else tighten the screws.
7/16 box end
Mentalpause 07-16-2005 12:41 PM
Originally Posted by DaveSunsation
Kirk,
7/16 box end
I mounted my box end on a 2 foot long 1x2. It worked great.
