Swim Ladder
Anyone know what brand ladder that Sunsation uses on their 32 footer?
thanks |
Re: Swim Ladder
Not sure of the brand, but give Joe a call at the factory (810)794-4888 and he can set you up on where to get the ladder, spacers and lag bolts.
Re: Swim Ladder
The lag bolts that come with the ladder are useless!
Buy some rubber gromet jam nuts. Use a hole saw for the hole, and insert these. Then tighten up. I did mine that way (because there was no axcess to them from inside) and four years latter it's still strong! Lag bolts into the fibreglass with make a real mess. Factory is nut and bolt, before the top cap is placed on. |
Re: Swim Ladder
Re: Swim Ladder
Buy some rubber gromet jam nuts. Use a hole saw for the hole, and insert these. Then tighten up. I did mine that way (because there was no axcess to them from inside) and four years latter it's still strong! Lag bolts into the fibreglass with make a real mess. Factory is nut and bolt, before the top cap is placed on. I got the package from Joe and Wayne, with directions, lag bolts, spacers et, and it installed without a hitch, and I never had a problem. And as K4M says, I do test strength and stamina. That ladder installed via Joe's kit and direction will lift 260+ boys year in and out without a strain. Not sure what your experience was, but it was nothing close to mine. My advice would be call Joe and implement the standard package as directed. |
Re: Swim Ladder
I was afraid and had never really screwed wood lag bolts into glass before. Didn't want to crack anything, so I went the rubber jam nut, and has worked perfect. I was in the engine compartment reaching into the swim platform cavity and couldn't feel any wood. So it concerned me.
But if you guys have done it, I guess its fine. I know Kanookster did the same as I did. |
Re: Swim Ladder
Depends when the boat was made, some have wood some don't
| All times are GMT -5. The time now is 11:08 PM. |
