Ok, how does it work?
I'm interested in the 32SS. Where does the sink water drain to? I didn't think the 32SS had any gray water tank...
Also, anyone know if you can get the 32SS with vacuflush and holding tank or just pumpout? It seems like vacuflush is nice, but might be a bit much to maintain after a few years.
One more, if you order A/C can it also heat the cabin? And how much/what type of maintenance will the A/C require to keep running year after year?
I'm in CA, so no winterization should be necessary...
Thanks,
John
Thanks,
John
Re: Ok, how does it work?
Call the factory and ask Joe.. GREAT guy and ALWAYS goes way out of his way to make sure current owners or potenial customers get any info they may need.
Can't say enough good about the Sunsation clan as they are top notch folk!
All i can tell you about is the A/C question...and yes you can order one that can supply heat...but you have to specify that...most are only chilling units. The other questions i would just call the factory direct to find out...i'm sure you could have it setup anyway you wanted.
-Wally
-Wally
My sinks drain out to through hull fittings, so they drain outside the boat. Even if you have to winterize the air unit, it only takes a few minutes.
nauticaL ILLUSIONS
7
07-22-2003 12:16 PM
