-   Sunsation (https://www.offshoreonly.com/forums/sunsation-43/)
-   -   High Speeds in the 288 (https://www.offshoreonly.com/forums/sunsation/207912-high-speeds-288-a.html)
ZXXX Donzi 05-03-2009 10:57 PM
[QUOTE=risingsun;2858061]
Originally Posted by ZXXX Donzi (Post 2856753)
Oh I actually have more beans left in my system. My comment was that things are getting pretty squirrely at 95. Some of that is probably seat time. I am in the process of adding bigger tabs. That should help some. I can spin my 850 harder. It will pull to 6,200 and make 942 hp and that is before race gas. That is starting to get pretty far beyond the limit of my drive. I am not trying to set a record, just have a little fun without getting anyone hurt. I have heard rumors of my hull being taken to 105 and that was not pretty. On the other hand, I have heard that my hull is done at 85 and that is not true either.
How does that big Nordic handle at 115? There is one around here that likes big power. It should be a good bit more stable than mine as it is more boat. I felt sure that some one was seeing numbers like that in a 288.
I want to enjoy the upper limits of single-enginedom before it is time to write more checks.[/QUOTE
That wasnt meant the way it sounded,sorry. Just most people won't spend the extra cash to push it that far. The motor is only part of it as you know. hyd steer,bigger tabs, stronger drives,and the list goes on! Glens 28 heat runs great! The drive is the week link,he has 1300 hp,. He does a good job driving at 110 and burst to 115. I posted some pic of it on the nordic side.I called about putting big power in a 28 and they said there looking into it. I like the new 28 also and I'm with you on the check writing I just love to BOAT!!!
Nice looking Aggressor. What kind of power are your running? Looks like a blast.
1,300 through a Bravo is pretty good. That makes me feel better. I have a friend running 1,000 a side through Bravos and I thought that was pretty good. It is all in how your drive.
risingsun 05-04-2009 06:59 AM
Originally Posted by fast fun 2 (Post 2858032)
Ive drivin a 32 Sunny (single) at a lil over 90 with no walk issues at all. Handled nice :cool: Nice package but took a lot of HP to get there. Its a different style boat,but, If you dont mind a less plush cabin Ive run a 29 Kryptonite to tripple digits w/o an issue either. Both great boats :ernaehrung004:
That boat was for sale. I looked at it on line. sweet set up! I went out yesterday and turned the boost back to 11lb and she ran 96 on a hand held gps,got a litte loose at about 88,some port tab helped her. We were on the Ohio river after it rained for 2 days so stuff floating didnt look good to hit. It runs best at 90 but even that in a 25 is pushing it with other people in the boat.
risingsun 05-10-2009 10:25 PM
2 Attachment(s)
Originally Posted by ZXXX Donzi (Post 2858200)
Yes, I was aware of some of the racing boats doing it. Eddie Young had a Phantom with big power. He said it ran way north of 100 and did it well. I would imagine a few other of the race bred boats like Joker are good to go too.
Every one love's pic !! It's not a race boat but it works for me!!
eagledm44 05-25-2009 07:45 PM
Risingsun, How did your whipple run when you first put it in. I am having alot of trouble with mine. I insatlled it on a 2008 525 with low hours. I spent alot of money. It keeps shutting down and has burned the tips off spark plugs. Any help would be great. My 525 was super reliable but now has become worthless.
risingsun 05-25-2009 09:34 PM
Franks Marine in OH installed it new in 2004. No problems . last year I sent the computer back to whipple and had it set to run 11lb boost. Staff at whipple helped me alot with new setup ! I've not had any issues. they told me to change the head gaskets so we did. No spark plug problems.
bunbuster 05-25-2009 09:45 PM
I had a wipple in my 288 no problems ever, if your burning tips,i would think your are very lean, call Dustin he is very helpful.
eagledm44 05-27-2009 06:24 AM
thanks guys for the help. i talked to dustin and he is helping me out. hopefully we get this problem fixed because when the whipple ran good the boat was a demon at 90-92 mph
risingsun 05-27-2009 10:45 PM
Originally Posted by MahopacMarine (Post 2856253)
ZXXX,
We are still tuning and testing a 2008 MCOB 288. It has a 525 whippled with an estimated HP of around 780. So far, we have seen 92.1 on a half tank of fuel and 2 guys and equipment setting fuel pressure. We are hoping to squeak out a couple more with a prop change.
We found the boat to handle the power very well. At first we thought it may require a bit of tab, but found it to like neutral tab right now in a 1-2' chop.
Will it see 100????? Maybe with a bit more work. I think a reasonably safe speed with this package will be about 95-96.
The MCOB is also a bit heavier with a lower X dimension so that is stealing a few mph as well.
Good question, Thanks!
Are you still testing and tuning on the 28 whipple? You know every one loves info and pic !
eagledm44 05-28-2009 12:18 PM
i own the 288 with the whipple. we still tryin to get all the kinks out. the boat runs 90 all day so far but i think were gonna need to spin a 31 lab bravo cuz the 30 regular bravo is hittin the revlimiter
live wire 05-28-2009 04:12 PM
What do you think it is cranking out for HP to get you up over the 90 mark ?Are you going to make to the NYC run this year? I would be good to see you guys out there.
