which yearl
Looking to buy a sunsation 288. It'll be my first. Everything being the same HP,prop,gear ratio, etc...is there any difference in speed/performance between year models ex 2002-2005 etc. Thanks for any input.
2005 they went to a single step hull. Before that there is just a "Vortec" ventilator at the chine that resembles a step. So the 2005's and up will be the faster boats with all other things equal.
OK. How much faster are we talkin. Can anyone give some speeds with hps and year models. I want to make sure if I find one with the looks I like I want be giving up too much on the speed side if its not the newer year models
Originally Posted by dcm911
(Post 3948966)
288KID saw 69-70 on gps with his 03 288 and 24p labbed....
dcm911 email at [email protected] . My pm box is not working.
I'm running a 2004 288 Sunny with the 496 with a whipple and a set of CMI headers with dual ram ext steering and currently running a Hydromotive 5 blade 27Pitch and hitting 82 on dash Speedo:) and still can pull the kids on a tube. Sunsation 288 will give you the best of both worlds IMO.
Step hull 8.2 Mag HO 69-70 GPS every day full load.
I have an '06 but same hull as the '05. Bounces between 71/72 running 4800-4900 in slight water conditions with a half tank and 3 people. Found with a little trim and running tabs neutral (not in the full up) adds a tick or two to the GPS. That was a phone with a GPS.
Hey DY, I know where there is a good looking 06 within a couple of hours of you...Hint Hint
| All times are GMT -5. The time now is 01:40 PM. |
