03 288 MCOB Captians Call Flakeyness
Anyone ever have issue with their captains call on the 288's? My captains call switch sometimes works, but other times does nothing, once in awhile it seems to be half and half.
I've never had a boat with captains call and I've just had this boat a little over a week, so very new to me. I've tried switching the switch at idle mostly but also tried while up and running. Had the issue both running and idling. Any ideas on what it might be ....and is this kind of problem costly to fix? |
Most likely a weak solenoid, your boat is the same year as mine and i lost one last summer. when you flip the switch it would hold the exhaust open only for a few seconds and then shut. You can order a new three wire solenoid from CP Performance for less than $200.00 it takes about 30 minutes to swap them out.
1 Attachment(s)
First of all, do not switch the exhaust one way or the other if you are running over 3K RPM. First things first. How old is your battery? A weak battery will play havoc with the solenoids operating properly. If you have a fresh, strong battery then you need to check to see how much voltage you are getting to the solenoids.
Thanks guys. GREAT info. I did not know that about not switching if over 3k ...guess it's best to just switch when idling and that would be my norm except when it was acting up I tried it various times trying to get it to work. The boat just does not sound right running quiet. I''d prefer to have loud all the time rather than be stuck in quiet mode.
I've no clue how old my batteries are. I just bought the boat and the previous owner did not mention recently replacing batteries, and the batteries worked. I did not think to ask that question. As mentioned in another thread .... Mine does not have a battery charger onboard. Do any of the sunnys come with a battery charger onboard or is that an add on we have to add ourselves? I added one to my Baja and it worked out great. To keep batteries at peak performance I think the batter charger on board helps. What do you guys think? |
The battery charger is optional. We have installed many on all the boat models. You can add yourself also. We use Pro Charging Systems Dual Pro DP2 charger.
Thanks Jeff. With all the other nicities the Sunny's have I was surprised it did not have a built in battery charger, guess you have to draw the line somewhere. I'll plan to get the Pro Charging Systems Dual Pro DP2 charger added at the end of the boating season.
| All times are GMT -5. The time now is 06:13 PM. |
