Shifter cables
Hello, does anyone know what length and type of shifter cables I need for a 2002 32 dominator with 496’s? The cables I need go from the shifter to the motors? Thanks for any info. |
Hardin Marine - 3300C / 33C Maxflex Extreme Cable
It should have the length marked toward the end of the cables. Last measurements we have are for the SSR style deeper hull. Port side throttle 19ft, port side shift 17ft. Starboard side throttle 17ft, starboard side shift 14ft. Most accurate way would be to measure the actual cables in your boat. |
Thank you!
