Engine oil drain
I have seen on several Sunsations a drain tube/hose with plug that is connected to the engine oil pan and then connected to one of the hull drain plugs via a small cable. It allows you to easily drain the engine oil out a hull drain hole. I remember seeing these for sale in one of the boating mags several years ago but can not find them now. I am having the motor pulled out of my boat for a major overahul this winter and wanted to have one of those installed before it was put back in the boat. Can anyone help me with where I can get one?
Re: Engine oil drain
Is this what you're looking for?
http://www.cpperformance.com/product...oil-drains.htm http://www.amarket.com/imd042c.htm |
Picture doesn't seem to show the tether that connects the plug at the end of the oil hose to the bilge plug. Bam marine has it, but it costs $35. Better off buying whole hose assembly
I bought a couple, too fat to fit thru my bilge drain hole. still lot easier than sucking thru the stick. hook up elect pump to hose.
That's it guys, thanks
| All times are GMT -5. The time now is 04:55 PM. |
