-   Superboat (https://www.offshoreonly.com/forums/superboat-44/)
-   -   Y2K 30:how fast? (https://www.offshoreonly.com/forums/superboat/106074-y2k-30-how-fast.html)
thayes11 09-12-2005 11:45 PM
Re: Y2K 30:how fast?
WOW 94 MPH !!! Fasterdamitt, what RPM and Prop combo ?
FASTERDAMITT 09-12-2005 11:53 PM
Had a 32" Bravo1 at 51-5200 rpm. I need a 30" to get my rpm up to at least mid 5000's.
Pure Energy 09-13-2005 06:14 AM
I have a 30 I might not need. It is a lefty though. Let me know if you need it.
FASTERDAMITT 09-13-2005 10:56 AM
I will keep it in mind, thanks. I may have my 32 labbed. Not sure yet.
thayes11 09-13-2005 12:12 PM
Fasterdamitt: What does you Y2K weight with the motor ?
z.zuperboat 09-13-2005 12:23 PM
dont forget to add the weight for fuel.
FASTERDAMITT 09-13-2005 02:24 PM
I really don't know. It should weigh the same as a HP525 and race hull construction, because I have closed cooling also.
Superbabi 09-13-2005 02:58 PM
The rigged weight with a big block shoud be about 4500 lbs. Race lay up is about 200 lbs. less than standard lay up.
JCPERF 09-13-2005 06:19 PM
Originally Posted by Pure Energy
Not yet!!! Still trying props. 81 so far on gps
What happened?I thought it went 84 first day out :confused:
HuntingtonBeach 09-13-2005 06:40 PM
That was with a bad ECM and babying it for break in...
