-   Superboat (https://www.offshoreonly.com/forums/superboat-44/)
-   -   Rigging K-Planes (https://www.offshoreonly.com/forums/superboat/118447-rigging-k-planes.html)
SUPERSTITIOUS 12-16-2005 10:20 PM
Re: Rigging K-Planes
I guess JC's theory is to jus-slap-em somewhere in the middle to make everyone happy :rolleyes:
Superbabi 12-17-2005 06:09 AM
Do you think the last 4-5 Y2K'S tabs are all in the SAME PLACE ????
z.zuperboat 12-18-2005 06:26 AM
Tabs in my opinion should be as close to the center of the V as possible because when the boats flying on the pad or inner chines the tabs will not have to move alot to be effective. Now horizontal I think would make the boat more stabile for chinewalking and when you hit a turn you have something extra to help carve the turn instead of just sliding. When my boat was a bravo the tabs where in close, during the conversion to the speedy and the very short #4 drive enabled me to lower the motor in the boat almost 2 inches and still have a good X dim. In turn lowering the location for the stearing rams so the tabs had to be move out and with the bottom. Im not a racer so this is just speculation.
Superbabi 12-18-2005 07:14 AM
2 Attachment(s)
Well here are where mine are located.
SUPERSTITIOUS 12-18-2005 07:11 PM
2 Attachment(s)
Same as mine
Pat McPherson 12-18-2005 08:05 PM
OK Zuper,
I agree that having the tabs more inboard would have them engage the water sooner when the boat is running high.
I'm still struggling with the horizontal thing though.
I guess with having a notch in the transom, the water is going to come off the boat differently. I don't see it being better on a straight V with no notch.
Also, to your carving vs. sliding comment: I would think having the tabs more toword the keel would help there too. But having them horizontal would have them engage less in a turn then if they were parallel with the bottom.
Hey Lightspeed,
No expert insight for us?
z.zuperboat 12-19-2005 07:42 AM
Pat it depends on the tab your talking about. On turns the highside will be out of the water.
Pat McPherson 12-19-2005 08:07 AM
I follow you Zup, the lower tab would have a better angle to bite in a turn...
lightspeed 12-19-2005 10:49 AM
All I can Tell You Is I Dont Agree Where JC Wanted Me To Put The Tabs .I Have Always Put them 1 Inch Above The Bottom Same Angle As The Bottom And After Running The Boat to see If They Scrubbed Any Speed I Took The Pins Out took The tab Bottoms Off And Reran The Boat No Speed difference Ran The Same. The other way You Have To Put Too Much Tab Down To Contact the water Which Is A No no when Runnin In Big Seas Thats My Two Cents They Will Be 1 Inch Above On My Boat
Pat McPherson 12-19-2005 12:27 PM
Hmmm...
So it's all about speed... :evilb:
The picture is now becoming clearer... :cool:
With the tabs mounted horizontal less speed will be scrubbed as they are lowered.
With tabs mounted with the angle of the bottom, and then dropped below neutral, lots of drag is added. With both tabs lowered below neutral they will act together like a parachute.
Hey Light Speed,
I do remember seeing the K-plane mounted horizontal on two Kryptonites. Is that the norm from the factory?
