-   Superboat (https://www.offshoreonly.com/forums/superboat-44/)
-   -   X-Dimension on the Y2K (https://www.offshoreonly.com/forums/superboat/125866-x-dimension-y2k.html)
Pure Energy 03-26-2006 01:37 PM
I know this has been touched on before but anyone have any further testing??
Mine is 1-1 1/2" higher than from the factory. I have not measured it yet to be exact. I remember reading that it should be kept lower for more bow lift but have spoke to others saying try higher.
Any thoughts??
Pat McPherson 03-26-2006 06:24 PM
Re: X-Dimension on the Y2K
Lots and Lots of Talk on this subject.
Krackmeup has done the most recent testing, so get with him for results.
I believe that the "standard" X- dim for a Y2K is around 18-1/2" which would put the prop shaft about 4-1/2" below the bottom.
If your boat was rigged with the prop shaft higher than the "standard", your boat will likely benefit from adding a spacer.
krakmeup 03-26-2006 06:37 PM
Pat's right, I have only about 3 hours on my newly added 1" spacer and the boat is MUCH better. JC and Rick have done a lot of testing and believe it is where it should be (according to JC), but we all know it needs a bit more bow lift. Since I have added the spacer I get less blow out (still owe BBlades a call to optimize from my 26P non-labbed Bravo 1 prop) and the boat just feels better, and turns quicker for sure. I posted all this, not sure where anymore, but do a search to see if you can find the data, or call me sometime - PM me for a phone number if you like!
Keith
krakmeup 03-26-2006 06:54 PM
Just found it - see the Hydromotive P5 post
FASTERDAMITT 03-26-2006 10:48 PM
I believe my prop shaft is 3.5"s below the keel.
