-   Superboat (https://www.offshoreonly.com/forums/superboat-44/)
-   -   superboat transoms (https://www.offshoreonly.com/forums/superboat/131332-superboat-transoms.html)
rch662 05-29-2006 09:12 PM
superboat transoms
Hi all, i was just doing some clean up on my 24', when i pulled the caps off the top of the transom to have them powder coated, i was surpised to find the core does'nt appear to be plywood, or is just the top capped off with a resin and something mix ? and are the transoms plywood from there on down ? thanks for any input. Rick
z.zuperboat 05-30-2006 06:43 AM
Re: superboat transoms
to my knowledge all the transoms are ply with the top glassed and gelled.
SUPERSTITIOUS 05-30-2006 11:53 AM
What Z said.....
TeamSaris 05-30-2006 07:09 PM
Originally Posted by OH-ZONE
What Z said.....
yep and VERY strong...
rch662 05-30-2006 10:38 PM
nope, not glassed and gelled, maybe somebody did something along the way, it's rough and porous. not really a problem just courious . thanks Rick
FX10 06-03-2006 12:30 PM
The transom and motor well are glass together. The top edge has around a 3/8" hollow, which is filled with a resin/sawdust mixture. The stuff is very strong, much stronger then a cab o sil and resin mixture. Under that, the plywood transom is fully encapsulated with fiberglass. If you see a crack in the filler on the top of the transom, don't worry about it. It's cosmetic, not structural. Squirt a little 5200 in there and put the cap back on.
Rick
rch662 06-04-2006 10:51 PM
thanks Rick, i was'nt sure what that was. anyway, i drilled a few holes in it to find out water made it through the cracks and down inside, any tricks to dry out the water ? or am i in oh no land ? thanks Rick
