-   Superboat (https://www.offshoreonly.com/forums/superboat-44/)
-   -   Superbabi's goal for 100+... (https://www.offshoreonly.com/forums/superboat/132394-superbabis-goal-100-a.html)
TeamSaris 06-10-2006 04:45 PM
can be done in an sb...
http://www.offshoreonly.com/esvon/page-10682.html :evilb:
Superbabi 06-11-2006 04:59 AM
Re: Superbabi's goal for 100+...
Johnny I was thinking Cat until I called up INSU. CO, I was told I could not be insured without prior Cat experince. :( Gonna have to do it in a " V " !!!!
Pat McPherson 06-11-2006 08:02 AM
Gary,
If you want your babi to run 100mph you will need about 900HP, right?
Your 502 block can be rebuild with a stroker kit to make it a 540cube. Then bolt that Whipple back on with a larger inter-cooler and a pulley set to crank up the boost. If none cracks the code on the existing computer, you need a new ignition and ECU combo. The GM MEFI 4 is the system a lot of builders are using these days. 900HP is vary much within reach with a supercharged 540... :evilb:
As for the out-drive, check out the B-max (Bravo Shop)... :drink:
It's only $$$$$$$$$$$$$$$$$$$$$$$$$$$$ :eek: :eek: :eek:
lightspeed 06-11-2006 08:07 AM
Better Start Lookin For Another Boat ///////////////
Superbabi 06-11-2006 09:03 AM
Yep, another Y2K, with the new bottom !!!!!!!! :D :evilb:
Pat McPherson 06-11-2006 09:06 AM
:p :p JD seems to be the mood to sir things up. :p :p
TeamSaris 06-11-2006 09:08 AM
Originally Posted by Pat McPherson
Gary,
unless you use a merlin or dart block it will never last. GM rates there 502 for 750 tops!!
Pat McPherson 06-11-2006 09:17 AM
Good point, the cast main caps will not hold up to 900HP.
What if you rework the block for steel mains with splade bolts?
Are we sure the 600 is not build on a bow-tie block?
If not, I guess a new short block is in order then...
More $$$$$$... That's OK we're spending Gary's money... :evilb:
Superbabi 06-11-2006 10:41 AM
Money I don't have........................... ;)
TeamSaris 06-11-2006 03:59 PM
90% sure we have built a couple 800+ bowties stock block they are weak i would go merlin for safety...
