Hyd Steering Hose Dims on 24'
I need a little help. I am trying to order a steering kit for my 24 and need some hose dimensions. My boat is a ways away in storage, and I can't go measure until this weekend probably. I thought I'd ask if anyone has hose dimensions for these that they have measured previously. I am adding only the interior portion as I already have the external steering. It looks to be WPM. Is that what John uses for the factory external? Any thoughts?
t-island just did the job and should be able to help you.
Sweet! Thanks again Pat! T-Islands? you out there?:D
I cut and terminated all the hose to fit exactly. So unfortunately I do not have the specific lengths. My kit came with a 80' of hose and I had extra left over.
I can make measurements tonight if you would like. I need to know which side your ram in on and your pump. Oh yea, I have a 496 which puts the pump on the port side and my ram is on Starboard. |
Originally Posted by t-islands
(Post 2096662)
I'll measure so you have something to compare with. I will be in the shop tonight anyway and it will take a couple on min.
Thanks T!!
Jay, Check your PM....
| All times are GMT -5. The time now is 07:07 AM. |
