-   Superboat (https://www.offshoreonly.com/forums/superboat-44/)
-   -   P5-X Props (https://www.offshoreonly.com/forums/superboat/156232-p5-x-props.html)
Stormrider 06-04-2007 09:22 AM
pat, what was the diff at cruise speed?
Pat McPherson 06-04-2007 09:36 AM
The cruise speeds are vary similar. Maybe 100-150rpm more at 50mph with the 5 blade. Remember the 5 blade is a 25p and my 4 blade is around 27p though.
The 5 blade really shines in the rough. The boat does definately run more stable at high speed in the rough.
Pat McPherson 06-04-2007 09:40 AM
Originally Posted by marylandmark (Post 2149911)
That is why you would go to this prop anyway- losing top end is a known...
Not necessarily true.
Some of the guys that have run them on 30' Supers have reported the same or even faster top speeds vs. a 4 blade.
krakmeup 06-04-2007 09:50 AM
Pat, sent you PM. I'm considering Whipple options so I would have to re-prop, but I'm still interested. With my buddy's 26PX5 I saw increases across the entire range - + 5 mph mids, +3mph top end and more stability.
Stormrider 06-04-2007 10:38 AM
Mark, i would take losing 2 up top for 3-4 more at cruise.
krakmeup 06-04-2007 11:00 AM
Originally Posted by marylandmark (Post 2150016)
Yep- me 2!
There are no absolutes. Here is my data for prop testing to date. Enjoy the analysis that will follw from a post like this! :D
Prop/ Blades/ Pitch/ Labbed?/ 3500/ 4000/ WOT/ WOT RPM/ Notes/ Day/ Conditions/ % Slip @WOT
Hydromotive P5X 5 26 n 47.5 57.5 73.8 5150 P5's are clever style, P5X are round ear 1 Cool Fall Day 13%
Hydromotive 4 n 45.2 54.3 72.3 2 Cool Fall Day
Hall's Vel Stage I 4 30 y 41.3 50.5 70.7 2 Cool Fall Day 12%
Mercruiser Bravo I 4 26 n 40.9 52.4 71 5150 at rev limiter 1 Cool Fall Day 12%
Mercruiser Bravo I 4 26 n 43 53 68 4800 4800 4 July 2006, Hot summer day. Now with Drive Spacer (1") 11%
Mercruiser Bravo I 4 26 n 44 54 71.5 4900 Mar 2007, cool day 7%
Merc Maximus 5 26 n 57.5 68.8 4950 not at rev limiter, excellent handling 3 Warm humid summer 11%
Pat McPherson 06-04-2007 02:28 PM
The P5X does seem to be the best prop for your hull Keith.
I do know that on OH-Zone's boat the top speeds are about the same with a P5X vs. a B1 and cruise is better with the 5 blade as well.
On my 24' the P5X is only better for rough water handling. I will probably not spend the $$ on this prop as I do have other items on my boat requiring attention/$$ right now.
krakmeup 06-06-2007 09:34 AM
Thanks for all your help and input Pat. I'll keep looking for a PX5-25 LH until I make any other changes.
Pat McPherson 06-06-2007 02:21 PM
No problem Keith. Keep me in mind if you find a killer deal on a pair.
The timing is just a little off for me to buy this prop. I was ready to pull the trigger a month ago, but.
Just got other items on the boat to spend $$ on right now...:rolleyes:
krakmeup 06-06-2007 02:38 PM
I hear ya! Don't worry, if Ifind a smokin' deal on a pair you'll be second to know about it!
