-   Superboat (https://www.offshoreonly.com/forums/superboat-44/)
-   -   Drives ??? (https://www.offshoreonly.com/forums/superboat/173102-drives.html)
Pat McPherson 11-13-2007 07:45 AM
Faster has an 800HP in the same boat with the same XR drive as you G.
Like I said when we talked, just buy a spare so you are not down for long when/if the drive breaks.
You are a Merc guy, just buy a spare Merc XR.
Stormrider 11-13-2007 08:26 AM
mdg seems happy w/ his konrad setup.
BUT, I'd say it'd be easier to have 3 XRs.(1on the boat, one ready to go, and one can be at shop)
And you can buy used XRs.
MDGperformance 11-13-2007 07:30 PM
Gary the Konrad ace will get it done on the y2k,more expensive ,but will save you in the long run.The bravo drives behind 800hp is a grenade with the pin out,its just a matter of time BOOM!.The B-max has the strongest upper but you will have to run a 1.3 ratio which your boat probably won't like.The teagues and imco might be a little better than the mercs,but not much.I have customers that have better luck with mercs ,some better with imco,teagues.I do think that if you use a imco torsional input shaft(used on there extension box)that helps absorb the load.I don't think they make a shaft for the merc its set up,but need to find out.I set up a 38 cig 509 blowers 700hp stock bravos with the imco shafts,boat has over 250hrs no drive issues,Randy at mti has also told me his cats running bravos do a lot better with the imco shafts,also a friend with a 37 outerlimits was told the same info from the factory.The bravo xr style drive will hold for a while but throttle man will determine how long,If you like to run it like you stole it,you better consider a Konrad.They are having a sale on them till mid December.This winter i am installing a set on a 38 powerplay(twin mdg700hp) and also one on a 29 fountain(single mdg950hp) we also might be putting a set on a39 mti(mdg750).Give me a call if you are interested will get a great price if we order them all at the same time.Dave 410-956-5381
TeamSaris 11-13-2007 08:01 PM
I agree th Konrad is the best bang for the buck, but it will be at its limit.And I have plenty of experience with them.Im also a dealer.There an awesome drive,but over 800HP you need an Arneson or a 6 for zero drive problems.Period.
MDGperformance 11-13-2007 08:19 PM
Gary just step up,put a 6 speedmaster and order yourself a Sterling 1550hp,it is almost christmas,your wife won't mind its only money
Pure Energy 11-13-2007 08:38 PM
Gary, I think any XR style drive is not going to last. Your are building a very serious machine and I don't think you want a drive to let go at 95 mph!! You also don't want the feeling that eveytime you go out it is going to be the time it blows. I think the Konrad is the way to go.
TeamSaris 11-14-2007 06:12 AM
:D:D
Superbabi 11-14-2007 01:55 PM
Thanks, for all the info. on the drives everyone. Dave ( MDG ) you sure know your stuff, the guys in your area are sure lucky to have someone like you doing there work !!!! For now its a wait and see what happens. If I can sell the whole pkg. as one it will be a new superboat, otherwise the motor will be sold and a 800efi will go in the existing hull. Perhaps a spare xr will have to be the ticket.
Pat McPherson 11-14-2007 02:31 PM
G., just by a spare. They are 4-5K used, 7K new...
http://www.offshoreonlyclassifieds.c...o19178-en.html
From what you've told me, you are not hard on the boat.
Pat McPherson 11-14-2007 02:38 PM
By the way, SB30 (Scott) is running a procharged 496Mag through a standard Bravo 1 for 2 years + with no problems.
My bud T-Mone has run 600HP through a standard B1 on his 24' Pantera for 4 years and believe me, no one runs harder.
With 800 in your boat, sure it will blow eventually, but you could replace it 3 times before spending the $$ for a different drive.
