-   Superboat (https://www.offshoreonly.com/forums/superboat-44/)
-   -   Swim platforms on 24' SB (https://www.offshoreonly.com/forums/superboat/181417-swim-platforms-24-sb.html)
DEVO24 03-05-2008 08:11 AM
I was wondering if anybody put a swim platform bracket on a 24SB before. I have a 225 Merc on a 6" setback.The boat is a 1983:I had it repainted ,new double steering,seats,bah,bah,bah(its only money and you cant put it in your box when your dead)I use it on the CT river and sometimes go to the sound(old Lime).Great riding boat and can take some waves.... The only thing is when boarding and doing water sports its a ***** getting back in the boat!!!!!!I know stainless marine makes them, but I dont know if that is to much setback.If you could help that would be great.The boats under wraps til spring then I'll send some pics!!!
rchevelle71 03-05-2008 08:22 AM
I am thinking the same thing for the Pantera, check armstrong brackets also.
Pat McPherson 03-05-2008 09:22 AM
Hi Devo24,
I ran a 24' Super on the CT River for the last 5 years.
There are a lot more guys on Scream and Fly that can answer your setup questions concerning an outboard powered 24 Super.
http://forums.screamandfly.com/forums/
Good Luck with your project and we'll see you on the River come Spring...
CMC 03-05-2008 06:23 PM
Stainless Marine will make anything you want.
supper 03-06-2008 09:57 AM
DEVO I assume you have that boat for its ride qualty especially in the ruff which is what they do best and fly pretty level ,family friendly on other hand ,but no dont do it its too much set back it would change the attitude of the boat especially with todays heavy motors i would try lookn up those venders that make those shortys that can go on either side of motor they make nunber of lengths widths and colors
rchevelle71 03-06-2008 10:34 AM
most motor brackets have flotation which offsets the weight of the heavy motor, the Armstrong actually extends the vee, making the running surface longer also:D
z.zuperboat 03-06-2008 10:52 AM
Extended running surface sounds like its going to hold the nose down
supper 03-07-2008 01:24 AM
flotation is only going to help when the boat is not on plane and as it just sits in water, not when your running on plane and weight is weight on the back, when your flying the boat what would floatation do in mid air the weight effects the attitude of the boat maybe not on a real heavy boat
DEVO24 03-07-2008 04:59 AM
Thats what I was worried about was the major change in the boats attitude....(not to mention trashing a custom swim platform because it dosent work)Thats why I'm checking with you guys!!!!!Thanks
rchevelle71 03-07-2008 06:09 AM
That sounds logical, I didnt think about when being airborne:D
