-   Sutphen (https://www.offshoreonly.com/forums/sutphen-64/)
-   -   Shorter Drive on an Ocean Pacer? (https://www.offshoreonly.com/forums/sutphen/178367-shorter-drive-ocean-pacer.html)
Jammin' 01-26-2008 12:16 PM
How does the 30' Ocean Pacer respond to a 2" shorter drive a la Konrad? Has anyone put the Konrad drives on this hull?
jeff1000man 01-26-2008 01:01 PM
THese make an ocean pacer haul azz.
here used to be one down here onthis lake with mild small blocks that would run in the 80's
http://www.offshoreonlyclassifieds.c...o20805-en.html
Jammin' 01-30-2008 10:34 PM
No history on this?
TOASTY 01-31-2008 05:36 AM
where is your x now. my trs are high and the boat runs great
CDC
Jammin' 01-31-2008 06:20 AM
I'll measure it. I assumed that TRS boats would all be the same. I'm looking at what the likely difference would be on this hull with a drive like a Konrad which is a little less than 2" shorter.
TOASTY 01-31-2008 05:13 PM
no, they are all different, lucky would have a better idea, b/c he had a few of them but i know my drives are high, and they are higher then most cigarette 38s or 35s with trs b/c they are tanks to get on plane. i like the way my boat turns kinda like a step bottom boat with the right props, i can slide it all over, it just feels so nice right on top real flat turn feels like its on rails. Some Konrads i have heard lost a few mph...or maybe they just dont know how to set the boat up with props...i would only try them if i can keep my crash boxes, and i am not chasing my drives to hard...
CDC
TOASTY 01-31-2008 05:18 PM
3 Attachment(s)
trs drives
Biggus 02-01-2008 06:55 AM
1 Attachment(s)
[QUOTE=TOASTY;2428087 Some Konrads i have heard lost a few mph...or maybe they just dont know how to set the boat up with props...i would only try them if i can keep my crash boxes, and i am not chasing my drives to hard...
CDC[/QUOTE]
Christian, please let me set the record straight while we are talking TRS conversions. I've been heavily involved with Konrad's TRS conversion since day one. I've got the very first TRS boat to be converted to the Konrad 540 system and have logged countless R&D hours dialing in this package.
To date (well over 100 TRS conversions) we have not seen any TRS swaps run slower. Typically, we see a 3-5 mph increase in speed. This increase can be attributed to the higher propshaft height (1.7") over the TRS as most TRS packages were installed rather deep.
Occationally, we encounter an application when the TRS was installed at a higher than normal X-Dimension and might require a spacer to bring the prop shaft down to the existing height. Even with spacers installed these boats have run the same speeds. We've never seen a loss of speed with the TRS conversion. Quite remarkable as the Konrad drive has much larger internal components and holds 6 qts of gear lube. Even with the increased viscous drag and larger gears, bearings and shafts they run the same speeds. This is credited to the much improved hydrodynamics of the Konrad lower gear case. Simply put they are a more efficient design that has proven to be extremely durable in these applications.
And yes, the Konrad unit will work fine behind your crash box.
[email protected]
Lucky Strike Jr 02-01-2008 09:10 AM
I'm not sure about the pleasure boats, but the race boats were all set-up different. For instance, the Blue GA had a fairly normal X dimension becuase it was a P Class boat. However, TOASTY/MAGIC J was a S class boat and had a very high X. The white GA Sutphen has a fairly high X too but gets on plane very easily.
Biggus 02-01-2008 09:24 AM
Bobby,
When you get a moment, could you measure the X on your 31?
Thanks,
Kurt
