-   Sutphen (https://www.offshoreonly.com/forums/sutphen-64/)
-   -   X-Dimension (https://www.offshoreonly.com/forums/sutphen/181659-x-dimension.html)
Black Wishbone 03-08-2008 09:25 AM
X-Dimension
I don't know if Sutphen standardized the X-Dimension on their boats. If so would anyone know what a 97 34' would be.
Dan do you still go to OP offen? I am looking to get the gear ratio on the outdrives and the prop size. My port prop seemed to cavitate at times. I have no idea where it is I think its in one of the hangers.
I am trying to look to get the best setup for this boat. I don't care about the hole shot, a good top end would be nice but mostly looking for a nice cruising speed.
shaun harrington 03-08-2008 12:12 PM
x
recently talked to sutphen about x for my boat I am repowering with boxes and bravos, from t r s . call me I will tell you what I know.508-326-7915
OL40SVX 03-10-2008 10:19 AM
I am at school in RI so i cant really go anywhere till May. I am friends with the previous owner though. It should say on the props what pitch they are. What i would do is once you find out the X (measure it), and current props give Throttle Up a call and they will provide you with a set up that your looking for prop wise.
Black Wishbone 03-11-2008 11:01 AM
Dan I did not relize you were not around. I will have to take a ride up to OP it's just an hour away and there is nothing else up there for me to do. If they were in the city it would be easier to drop in.
Thanks anyways.
ChristianGott 03-11-2008 07:02 PM
bwish...i'm out that way every other week (usually at bill's at the singing bridge/westbrook), what info do you need, i'll try to stop in for you...
