Originally Posted by RFCB
(Post 3874974)
It was originally rigged with a pair of 720hp engines with speedmaster #4's on extender boxes. Best we saw was in the 98mph. The boat was re-rigged to Factory 2 specs and would touch 90 as fuel was burnt off. The boat handled better in the rough with the F2 set up. Not as much weight hanging off of the transom.
We never had 28's when we had it. We had a set of worked 30 Bravo's and a set of worked 30 or 32 Hydromotive Quad 4's. I believe we spun them up to 5400-5600 rpm. The Hydromotive props were faster by a few MPH. What direction are you turning the props? It is faster turning them in.
some of this stuff is over my head but not my PARTNER dan who owns inland marine .he installed motors himself along with everything else needed for blower motors..ect ect..these motors fit perfect in boat and run great. im sure he gets all of it and knows which way props turn.your imput will help us. we will keep you posted. thanks .....
(Post 3941929)
thanks
(Post 3941929)
Originally Posted by dba900
(Post 3942369)
So I'm clear, what are Factory 2 specs? Drives on the transom?
http://www.p4-34.com/public_html/FactoryClasses.htm Basics for F2 were Factory spec'd 30-39' with twin HP500's/Bravo |
30 Sutphen held kilo record for 2 years
The 30 foot SUTPHEN held the kilo record the first few years, until Reggie had his own engine builder with a seal kit.
With two 725 HP blower motors, boxes, with a 1:50 drive, you should be in the 32 to 34 prop range.
thanks we re thinking lab finished 32 . but first this week tue or wed we will try hydromotives we got with boat. and we will see you at fall river poker run.
| All times are GMT -5. The time now is 07:42 PM. |
