-   Sutphen (https://www.offshoreonly.com/forums/sutphen-64/)
-   -   Transducer question (https://www.offshoreonly.com/forums/sutphen/305361-transducer-question.html)
floatingphil 11-14-2013 04:07 PM
Transducer question
Will in-hull (shoot-through type) transducers work properly on a Sutphen hull and provide accurate depths?
joew. 11-14-2013 06:19 PM
As long as it is not a cored hull, yes. Just installed one on my fountain.
floatingphil 11-15-2013 08:07 AM
That's the issue, my understanding is the bottom is cored.
wstultz 11-15-2013 08:31 AM
I put one on my new one. Ground it down and epoxied it to the inside. It works every once in a while. It reads depths when it wants to. :lolhit:
floatingphil 11-15-2013 09:57 AM
Thanks! You just saved me $250.00 and a bunch of aggravation.
wstultz 11-15-2013 11:26 AM
I wanted to keep the transom as clean as possible with as few holes as possible which is why I decided to use that one. The transom mounted one I had before worked much better. If you need to know accurate depth often I would stick with the transom mounted one.
