aeromotive fuel pump for mechanical
I have a new aero pump model 11101 and aero regulator model 13204 willing to trade for a seawater fuel pump and housing for a gen-6 502. hope thats better
what is a fuel fuel , and a v1 502??
I have a good used 6 vain, mechanical pump for a sea water pump that I would trade. Call me at 602-451-4519
Thanks Curtis @ Billetmarine.com |
so do you need just the fuel pump or the sea pump also? I have a new fuel and used sea let me know. Is this for a carb set up of EFI?
I need both sea pump and fuel pump,it's a carb engine 540 hp. I also need the brackets and pulleys. I can be reached at 203 877-7560 Thanks
To be totaly honest I would run the aeromotive with that kind of HP. The stock set up will probably not be able to keep up. We just had to switch out a stock set up on my buddies 540 600hp motor. the mec. pump would/will drop off psi at high rpm. Just a thought B4 you waist your time and money.
| All times are GMT -5. The time now is 01:24 AM. |
