-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Alpha SS drive (https://www.offshoreonly.com/forums/swap-shop/197627-alpha-ss-drive.html)
ACrooks69 10-21-2008 01:54 PM
Alpha SS drive
Hey guys, I selling off the speed parts off my 91 185 Searay and this is the next item. http://www.speedwake.com/newclassifi...p?product=1227
$3500, Alpha SS drive in great running condition. I don't have to explain ho hard it is to find these. 1.5:1 final gear ratio.
Removed from my 185 Searay because I am selling boat and putting back to stock. Drive needs nothing except for paint (which I am going to do). I sanded the skeg down to test theory of faster with no paint. Upshot is you can see the skeg has never been replaced. Upper gear set was replace a couple years ago, inspected a couple of weeks ago and still look new. Bottom was inspected when the gears were replaced and everything was OK. Used Mobil 1 until this year, then switched to Amsoil GL. Never found any water in lube. Had a drive shower but is not included in this sale. Water pump was replaced before Labor Day and has been run twice.
I had this drive mounted on a Alpha Gen 2 ('91-up) gimble, so if you have a newer boat and want to be able to take advantage of this performance drive I will swap out my modified trim rams (to get correct trim range) and bell housing with necessary shift shaft for your existing standard units straight up. Very top of the CLE has a shallow relief for the trim cross pin. Will still bolt up directly to any gen 1 gimble.
This drive increased my speed from 69mph to 75mph (also need to increase pitch due to RPM increase). Greatly improved the stability at top speed, and acceleration from 50 up was amazing. Am going to miss the boat going into the future and this drive added a lot of fun to it.
I also have a spare lower vertical shaft that I will include as soon as I dig it out of the garage. Don’t know what that it worth today, but you cannot get it anymore and if you were to break it you would be SOL. l also throw it the $70 hose flushing attachment. Any other question, feel free to ask.
HIGH LIFE 10-21-2008 04:55 PM
Alpha Ss
You should try posting on the DONZI web site, they would die for 1 of these!!!!!!!! HIGH LIFE
ACrooks69 10-21-2008 05:08 PM
Oh, I know it. Already done.
BUIZILLA 10-21-2008 06:22 PM
too much bait..
ACrooks69 10-21-2008 06:53 PM
Hey, when an outboard lower CLE is going for $2500, a 1000 more is not to much to ask for the sterndrive specific upper, a spare vertical shaft and the hose flush kit. Try finding one elsewhere. Plus, when a -2 bravo shorty only goes for about the same as this complete drive... I don't need to sell it, I'm just not going to give it away.
BUIZILLA 10-21-2008 06:57 PM
I had one for several years... yours is the most expensive ever listed on this planet, good luck with the sale...
when you can buy a complete Bravo 1 drive, gimble, transom mount, and rams for this or less money, ya gotta look at every equation..
just my .02
ACrooks69 12-03-2008 02:03 PM
Bump
erickoster 01-26-2009 02:13 PM
Originally Posted by ACrooks69 (Post 2752020)
Bump
I'm interested in the vertical shaft. Please reply, email or call. Thanks
Eric Koster
eric@jhmarine
209 992 2958
Donzilla 01-26-2009 06:01 PM
just my .02
I have bought them also and agree with you. And no picture?
ACrooks69 01-26-2009 10:25 PM
Wow, We know how to read! Check the top of the post Don.
BTW, Sold
