-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   still looking for EMI Thunder For Bravo app (https://www.offshoreonly.com/forums/swap-shop/206582-still-looking-emi-thunder-bravo-app.html)
Outlaw00024 04-09-2009 08:16 PM
Looking for a good used set of EMI thunder Manifolds and Performance tails.
Anyone parting with one set that are in good condition.
Pm me if you have.
Elite Marine 04-09-2009 08:30 PM
They are pretty affordable through Revolution Marine. Same manifold, made at the same foundry. We dont sell their exhaust anymore, its a price issue, not quality issue. Many satisfied customers.
Outlaw00024 04-09-2009 08:49 PM
Thanks I will keep that in mind :drink:
But looking for a good used set.. less $$$ :ernaehrung004:
Outlaw00024 04-09-2009 11:19 PM
Thanks for the post.. I went on their site, going to do some research on them. the price seems right for sure.
Also going to look at the engine pre-oil system.
I am not sure if the revolution Marine system will be ok with a 600 hp 502 application. Reversion ?
anyone running these, wonder how they sound?
Howitzers 04-12-2009 10:54 PM
Howitzers
The earlier Revolutions had a cast riser which I am certain will allow reversion on as hot a cam as you would need for a 600HP 502. However I understand that they (partnered with Eddie Marine, are now making a fabricated stainless riser like the IMCOs. That should better. But still that will probably allow reversion with that hot a cam, depending on the idle speed. IMCO makes a Powerflow PLUS which has individual runners that pass through the cast riser. 32 inch primary runners as I recall. With a decent length Dbl wall tail piece, that system should not allow reversion on your engine...
Good Luck.
