-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Konrad Marine Speedmaster Conversion Special! (https://www.offshoreonly.com/forums/swap-shop/208197-konrad-marine-speedmaster-conversion-special.html)
Biggus 05-05-2009 07:23 AM
2 Attachment(s)
Spring special on the Konrad 540 PRS III (SSM IIII) conversion kit.
The Konrad PRS III is a direct bolt-on drive unit for the Merc Speedmaster III. This system retains the existing Speedmaster transom assembly. All that's required is swapping out the SSM drive bell and installing the Konrad bell (included w/ new bellows) into the SSM gimbal ring.
Benefits include:
Almost 2" higher prop shaft height
Heavy Duty upper gear housing/input shaft
Wing plate steering cover
Next day parts availability in most cases.
Spring special $9995.00
Feel free to contact me directly for a dealer near you.
Kurt 715-410-0735
tgersx 05-05-2009 03:41 PM
would these replace #5's? dont they take the same transom assy, also what is the max hp they will take?
Biggus 05-05-2009 04:43 PM
Yes, we do have a package for the SSM V, It's basically the same upper unit as pictured but the lower gear case is 2" shorter. It puts the propshaft about 2" lower than the SSM V. The Konrad units run Bravo style props, since the prop dia. is reduced it seems to work better (and get on plane) a little deeper anyway.
The Konrad units are rated for up to 800 hp.
Feel free to call for more info.
Kurt 715-410-0735
