tie bar setup
saddle mount tie bar setup. it is 34-3/4" from eye to eye. can be adjusted longer.
http://i270.photobucket.com/albums/j.../tiebar001.jpg http://i270.photobucket.com/albums/j.../tiebar002.jpg |
still for sale
How much ?
$240 shipped.
Will that fit an Aplha one setup?
If so...I'll take it. |
not sure about the alpha setup. you may want to ask the question in the tech section.
How deep do the threads go inside the bar. My span is a bit shorter so if I cut off an inch on each side it will work for me.
I'll check it out tonight and get back to you.
The threads go in about 3" on each end. And the male threads are about 1-1/2" long. Theorectically you could cut 1" off each side and still have 1/2" of room.
How would you plan on cutting this ?? |
I have a friend with a machine shop. We could probably try the bandsaw with a diamond blade, or just stick it in the lathe and turn it down? If the hole is deep enough I can even run a tap into the end and re-thread a bit deeper if necessary?
Let me take another measurement of my boat tomorrow. I'll pull it out of the water and check again. |
Just checked again tonight and its exactly 31 inches from centre to centre on my drives. That would mean I would have to cut 1 1/2" off each end to make it work.
Is the bar solid or hollow with threads cut inside? I might be able to make it work with a bit of machining... |
Originally Posted by Stinger390X
(Post 2917636)
Is the bar solid or hollow with threads cut inside? I might be able to make it work with a bit of machining... Also if it really is ,,u only need to cut 1 side and retread inside. |
the bar is solid with about a 3" hole drilled in each side. the threads go pretty close to the end of the hole.
ttt
Did it ever sell? Does it fit Alpha drives? Inquiring minds want to know... :)
I still have it for sale. It came off a bravo setup, but looks like with some work, you can modify it to fit an alpha setup.
still 4 sale
| All times are GMT -5. The time now is 06:54 AM. |
