-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Complete 572 (https://www.offshoreonly.com/forums/swap-shop/210155-complete-572-a.html)
x7734x 06-02-2009 08:08 PM
Complete 572
Only 10 hours on the motor
730 HP on pump gas
Dart Big M 10.2 Deck Nodular Caps 4.500
SRP Pistons
Eagle 4340 Forged Steel Internal Balance Crankshaft 4.5 Stroke BBC
Eagle 4340 Forged Steel H Beam Rods with ARP L19 Rod bolts
King Alecular Pro Race Bearings Rods and Mains
Mahle File Fit Performance Ring Set
Dart Pro 1 345 CC Alum Heads- Fully Ported
118cc Chamber w/ ceramic coated crowns
Stainless Valves
1.63 Valve Springs
Titanium Retainers and 10* locks
DART stud girdles
ARP Headstuds
Comp magnum roller Rocker Arms
Mr. Gasket Solicore Head Gaskets
DART Single Plane Intake Manifold
Comp Cams Solid Roller Custom Camshaft
Comp Cams Solid Roller Lifter
Melling High Volume Oil Pump and Shaft
Professional Products SFI Internal Balance Damper
Milodon marine oil pan w/ pick up
Billet double roller timing chain w/ torrington bearing
CMI E-TOP headers
Tail pipes
MSD Ignition
MSD Billet Dist.
MSD Plug wires
H2O pump w/mounting bracket
Alternator w/mounting bracket
Power steering pump w/mounting bracket
Teague Valve covers
Barry Grant King Demon Carb.
K&N Marine Air filter
$14000 Or trade for???? Located In Las Vegas
Will email pics upon request
x7734x 06-08-2009 01:59 PM
Lowered price...$12000 or trade
x7734x 06-12-2009 06:46 PM
I forgot to include the following:
Teague Fly Wheel
Bravo Drive Coupler
Bravo Bell Housing
Hi Torque Starter
Merc Wiring Harness (motor side)
