-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Marine Machine Steering for Twin Bravo's (https://www.offshoreonly.com/forums/swap-shop/212406-marine-machine-steering-twin-bravos.html)
fireboatpilot 07-06-2009 03:01 PM
3 Attachment(s)
I have a Marine Machine external steering set up for twin bravo drives. All polished stainless steel. It is used but in great condition. What I have is the 2 rams, 2 wing plates, 1 tie bar 34-36", reservoir, filter, cooler and ram lines. What's needed is the interior lines, pump, the thru hull ram/line mounts and a helm or brazil valve depending on if you want it to be add on or full hyd. steering. $2,000. + shipping from Philadelphia, PA, 19136 or pick up is OK too. The extension arms for the rams are NOT included. I actually will have a second set up that is on the back of the cat now but won't be available until I put on the extension boxes and Imco drives at the end of this season.
fireboatpilot 07-08-2009 08:59 PM
Still Available. Get it now!
fireboatpilot 07-12-2009 05:20 PM
Ttt
