-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   need pair of 502 heads (https://www.offshoreonly.com/forums/swap-shop/221436-need-pair-502-heads.html)
kwooley 12-16-2009 10:30 PM
Need pair of 502 Mag Mpi VI heads, Castin # 14097088.
fleg1 12-17-2009 09:57 AM
I have a pair. 1 head needs repaired though it dropped a intake valve on #7 cylinder. My local shop wanted 170.00 to fix it, which was for a new valve guide, valve, retainer and keepers, and grind the valve seat.
d-zwisle 12-17-2009 10:00 AM
call leon dereberry he has them ready to go
dereberry performance marine pottsboro texas, byond reason skater
1-903-821-6654
Shock Therapy 12-17-2009 10:59 AM
I have two sets of ported heads from my 500EFI's. All four just machined and ready for assembly. $500 per set.
merlin 12-17-2009 11:42 AM
500 efi
Pm sent
kwooley 12-17-2009 11:50 AM
Are the heads for the 500EFI and the 502Mag the compatible? I am wanting to use the stock valves I already have.
This is my first marine engine rebuild, so I'm not 100% on what is and what is not compatible.
indywhsle 12-17-2009 02:13 PM
I have a stock set I took off my 502 when I went with aluminum. Let me know if you want them.
jeff1000man 12-17-2009 02:17 PM
I have a set also, but they need to be worked over. They are complete though.
kwooley 12-17-2009 02:48 PM
Both send pics please. [email protected]
could you also tell me the casting # just so I can double check?
indywhsle 12-19-2009 10:17 AM
Sent pics yesterday let me know if you want them.
