-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   2 500hp cams (https://www.offshoreonly.com/forums/swap-shop/223339-2-500hp-cams.html)
88scarab 01-25-2010 10:45 AM
2 500hp cams
2 500hp cams in great shape asking 300 for both
nxfirebird 01-25-2010 12:34 PM
are they the carbed 611's or the mpi 621's?
88scarab 01-25-2010 12:55 PM
carbd
crapr6 01-25-2010 04:38 PM
What are the specs on a carb hp500 camshaft. Is it hyd roller or flat tappet?
Iam also in Toms River and if intrested can buy one and pick it up.
Erik
88scarab 01-25-2010 04:39 PM
its a gen. 6 roller cam not sure on all the specs somebody on here will know that
crapr6 01-25-2010 06:12 PM
Do you know if a gen 6 cam will work in a gen 4 block?
Erik
88scarab 01-26-2010 04:11 PM
ttt
88scarab 01-28-2010 03:50 PM
ttt
formula377 03-14-2010 02:14 PM
Is there a lobe for the fuel pump on those cams?
1BIGJIM 03-15-2010 06:35 AM
Erik
It will but, you need to use single row timing set from Gen VI engine and have a retainer plate.
Easier to get a custom ground crank for your application IMO.
