Spring Mic New Never Used Comp Cams
68.00 SHIPPED TO YOUR DOOR CALL 734 -383-0730 OR P.M ME THANKS.
BRAND NEW COMP CAMS SPRING MIC 1.800" -2- 2.200" Brand COMP Cams Manufacturer's Part Number 4929 Part Type Valve Spring Height Micrometers Product Line COMP Cams Valve Spring Height Micrometers Summit Racing Part Number CCA-4929 Micrometer Range (in) 1.600-2.200 Micrometer Increments (in) 0.005 Maximum Valve Spring Retainer Diameter (in) 1.500 Micrometer Material Aluminum Micrometer Finish Natural Measure valve spring height the easy way. Accurate to .001 in., these COMP Cams valve spring height micrometers are the quickest, easiest, and most accurate way to measure valve spring installed height. They install just like a valve spring, and then the tool is expanded until it has fully seated the valve, locks, and retainer. By simulating the installation, they're able to read the measurement precisely. |
Hey when did you send thos e cams. They still not here
Originally Posted by sdrockslangers
(Post 3045629)
make offer need's to go
still forsale
Still forsale
| All times are GMT -5. The time now is 05:19 AM. |
