-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Holley 830 CFM 9381 (https://www.offshoreonly.com/forums/swap-shop/226243-holley-830-cfm-9381-a.html)
bck 03-12-2010 10:39 PM
Holley 830 CFM 9381
I have a pair of used 9381 Holley carbs. They are 830 CFM Competition Series. They are still available from Holley so you can check there for the exact specs. They have a used appearance and were working properly when removed. Will email pics or post here when I figure out how. I figure $200 a piece plus shipping. They are $449 from Summit.
•No choke hardware
•Center hung float bowls
•Dual 30cc accelerator pumps
•Annular style boosters
•Mechanical secondaries
•Four-corner idle system
kreed 03-13-2010 07:41 AM
pics to [email protected]
pachanga27 03-13-2010 09:00 AM
Send pics to [email protected] please very interested in one. My motor will be finished next week so sooner the better!
wjb21ndtown 03-13-2010 11:48 AM
Pics to [email protected]
Are these marine carbs or street carbs?
bck 03-13-2010 03:01 PM
Picture have been sent to the above addresses, let me know if you have any problems with them. I just sent pics of one carb for now as the other is in identical condition. The carbs came from engines I own and had no problems. I am getting rid of them as they are not ideal for my new engines. The carbs are probably a little less clean than the pics indicate because all pics tend to hide things. The pics are current, I just took them prior to sending the message.The spacer on the carb is not included. I would recommend they be dissembled and cleaned before use.
bck 03-13-2010 03:08 PM
I just looked at a copy of the email I sent and the pictures are sized much better if you open the attachments rather than view them as they appear in the body. Also the dirt was beautifully captured, they appear exactly as the pics indicate.
