-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   650-700HP blower engine. Brand new - ready to install (https://www.offshoreonly.com/forums/swap-shop/235919-650-700hp-blower-engine-brand-new-ready-install.html)
jeff1000man 07-31-2010 12:20 PM
2 Attachment(s)
I sold my single engine boat with no power. I am keeping the XR drive for a spare. I have a stock bravo gimble that looks brand new that I will sell for $1300 plus the ride. It has the internal power steering ram as well.
The engine is a 468CI, 9.8 deck BBC
Aluminum heads, Inconel and sever duty valves. Comp springs, crane gold rockers, Magnum push rods. Callies forged crank, 6.385 Manly I beam rods. ARP rod bolts, JE 7.5:1 dished piston. 250 Blower. twin 750 carbs. All fuel lines, flame arrestor included. Custom valve covers with built in spring oilers. Canton 10 quart maring pan.
Eickert 2 stage billet sea pump. mando alternator, New power steering pump. Billet Eickert accesories. Wiring harness installed, remanned hi torque starter, Bellhousing for Bravo and brand new HP drive coupler.
Comes with CMI exhaust, and thru hull tails for Bravo. 4.5" tails.
Comes with Hardin marine sea strainer, and Eickert oil cooler, chromed and ready to go.
You will need a few minor water hoses, and oil lines to install into your application. Otherwise eveything is there.
Engine did 675HP at 5500 rpms, set at 28 degrees total timing, and the needle still climbing, and only 6.5 lbs of boost.
This is a very conservative set up for this engine. It could handle a little more boost or timing and put you well into the mid 700's. Engine has dyno time only on it. This engine was built for my race boat that is now sold. It was designed for endurance, so in a pleasure/ poker run application, it should give you years of service.
Prices to sell at 20K
jeff1000man 07-31-2010 12:23 PM
Also MSD marine ignition installed, and includes a spare MSD box that has been back to MSD and condition verified by them.
If you would like to travel to see the engine I can put on the test stand and run it for you.
jeff1000man 07-31-2010 12:28 PM
Madero solid roller cam. ISKY red zone solid roller lifters.
To much extra stuff on here to list. Lots of money invested in this engine.
chaparral2300 08-01-2010 06:24 PM
would you be willing to sell the extra msd box, looking for a decent used one, ill be honest those engines and components are way out of my range, id love that engine, hell im in love wtih that engine, it matches my boat and all. man id give about anything for that.
