-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Merc Wiring Harness/dizzy/alt. (https://www.offshoreonly.com/forums/swap-shop/237328-merc-wiring-harness-dizzy-alt.html)
SINGLETGT 08-21-2010 10:30 AM
These parts were removed from an early 90's merc 330 hp.
This harness is setup for use of a knock sensor(not included) but is not required to work. The dizzy has the knock module on it. We had the engine running prior to me removing it. I have twins and wanted both motors identical. I dont know the amperage of the alt, but it must be more then 60amp judging by the dual pulley. There is one wire that is cut in the harness, Im assuming its use is in the trim sender system as it had no affect on the motor running on the engine stand prior to removal.
300 for it all plus shipping
Dominic
http://i771.photobucket.com/albums/x...0821101046.jpg http://i771.photobucket.com/albums/x...821101045a.jpg http://i771.photobucket.com/albums/x...0821101045.jpg
SINGLETGT 10-15-2010 01:48 PM
bump
