Two complete bravo set ups
I have two complete bravo setups for sale, everything from the motors back.
Bellhousings painted mercury blue- $120 each.............SOLD........... Couplers- $100 each shift brackets- make offer..........SOLD............. Transom assemblies with resevoir, inner plate, and trim cyclinders- $1200 each..................SOLD.................... Bravo drive 1.5ratio with LWP and small shaft, latham steering cap, and 2" spacer. drives has approximately 75hrs since rebuild.-$2500..............PENDING.............. Bravo drive 1.5 ratio with LWP and small shaft, latham steering cap, and 2" spacer. Upper has new upgraded gears and cone clutch and bearings. Lower has used low hour gears,new bearings, and seals. Drive has approximately 15hrs (half a summer) on the recent rebuild.-$3000.................SOLD UPPER,................ LOWER AND SPACER STILL AVAILABLE............... Pair of 34 pitch bravo props good condition, only have a couple of minor nicks that aren't even able to be seen in pics.- $650 All parts are used but in good shape, everything is on the boat but will be removed for immediate shipping and everything can be split up (uppers, lowers, and 2"spacers). pics will be loaded soon. Thanks Rob 513-884-2429 [email protected] |
5 Attachment(s)
pictures
Ttt
2" spacers.... $300 pair
34 bravo props.....$500 pair couplers......$150 pair Latham end caps for external steering (stainless powder coated silver).......$300 pair Bravo lower with low water pickup small shaft......$1000 |
| All times are GMT -5. The time now is 11:56 AM. |
