Teague high performance offshore oil cooler
I have a nice used Teague marine high performance offshore oil cooler. the cooler was designed especially for higher output engines, from 600 to 1400 horsepower and more! This oil cooler has the cooling capacity necessary for today's large displacement engines. Heavy-duty brass construction for optimum heat dissipation. The cooler body is 22.5" long with a 3.5" diameter body, two 1" NPT water inlets/outlets, and two 3/4" oil inlets/outlets. Lower oil temperature means less heat and stress on the internal components, resulting in longer engine life and greater dependability. Trust the most efficient cooler on the market. •Model: AIH AB702-11024 I do not have the mounting brackets for it, you can make your own or buy them from Teague. this cooler came out of my 21 v-drive Rayson craft and is to big, never been used in salt water. new $726.98 ill take $300.00 plus shipping. Weight is 25lbs• from 95991 thanks for looking. mike
http://www.riverdavesplace.com/RDP/s...arts%20002.JPG http://www.riverdavesplace.com/RDP/s...arts%20003.JPG http://www.riverdavesplace.com/RDP/s...arts%20004.JPG http://www.riverdavesplace.com/RDP/s...arts%20005.JPG this is what a new one looks like from Teague. http://teaguecustommarine.com//store...l_cooler-2.jpg |
| All times are GMT -5. The time now is 03:49 AM. |
