-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Couple of gauges needed..... (https://www.offshoreonly.com/forums/swap-shop/242193-couple-gauges-needed.html)
FogduckerIII 11-09-2010 12:10 PM
Good morning, I am in need of a couple of gauges.
I am looking for white face vacuum/boost and fuel pressure
(0-100psi)
Size or make are not an issue, thanks. Jeremy
[email protected]
FIXX 11-09-2010 04:08 PM
fixx
(0-100psi)
[email protected]
100 PSI:eek: thats allot of boost:grinser010:
FogduckerIII 11-09-2010 04:21 PM
My fuel pressure should be around 38psi right?
I figure with a 0-100psi the needle will read around the same level as the rest of the gauges when cruising, keeps things symetrical......:lolhit::grinser010:
PS. Got any gauges or are you just crashing my thread...?:angry-smiley-038:
FIXX 11-09-2010 05:29 PM
Fixx
i have a few just not the one's your looking for :)
fireboatpilot 11-09-2010 10:45 PM
I have 2 vac/boost gauges. One is a Livorsi and the other is an Autometer marine. Both have white faces and trim rings with red pointers. Both worked great when replaced because I no longer run blowers. $50. each free shipping.
Underdog88 11-10-2010 08:06 AM
sscompetition.com
insatiable5 11-11-2010 06:19 AM
have two Livorsi vac/boost gauges just rebuild by them 2" white $50.00
