bbc 088 rec port heads ready to run
I have 1 set of bbc rec port heads off gen 6 502 mag just back from machine shop all new exhaust valves, guids, new seats new springs retainers and keepers heads where resurfaced and tested also had some mild porting done.selling to go with a set of aluminum heads.800 or b/o plus the ride have all receipts from machine shop have pics also if wanted sold
heads
Will they fit a gen 4 block I'm not sure. Let me know [email protected] Thanks JOHN SR
Originally Posted by Fenderjack
(Post 3298511)
(Post 3298511)
Originally Posted by jeffswav
(Post 3299212)
No, If you have a gen V or VI block any version of heads will work. If you have gen V or VI heads they will not work on a Mark IV block. They may bolt up but I heard you will have problems. I have Mark IV heads on a Gen V block and they work fine. Just will not work the other way.
Ok, all cleared up. You can use the GenVI heads on the GenIV block as long as you use the genVI head gaskets for the proper water passages to line up! Ok....business as usual !
| All times are GMT -5. The time now is 12:07 AM. |
