BB blocks, heads, cranks, rods & misc.
- Mark 4 454 4 bolt .060 block, freesh bore and hone, 1972 casting #3999289 for the chevy gurus $750.
- Gen 5 454 4bolt .030 decked .010 block, fresh bore and hone, casting # 10114182, $550. - Gen 5/6 rect. port heads, casting #14097088 w/manley severe duty intake & inconel exhaust valves. Intake bowls blended fresh valve, job milled .020, no springs etc $600. - Gen 5/6 rect. port heads, casting # 14097088, needs 4 exhaust seats, bare $150. - Mark 4 oval port heads, open chamber, casting # 353049, complete $150. - Gen 5/6 454 cast crank, standard rods and mains, slight rust $100. - Mark 4 454 cast crank, standard rods and mains, spun rod journals $100. - Gen 5/6 7/16" bolt connecting rods $150. - Gen 5/6 3/8" bolt connecting rods $100. - Mark 4 3/8" rods with TRW # L2349, standard pistons, pins tight $200. - Comp cams, magnum roller tip, steel rockers, 1.7 ratio $75. Call for more info 914-262-1898. Located in NY. |
Are your magnum rockers the Pro Magnums or stampted steel versions? Thanks.
They are the stamped steel version. thanks
any 781 heads?
Just what's listed. Thanks
| All times are GMT -5. The time now is 08:52 AM. |
