-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   640ci bbc carb to oil pan. (https://www.offshoreonly.com/forums/swap-shop/248768-640ci-bbc-carb-oil-pan.html)
lake speed 03-04-2011 08:26 AM
motor consisting of a Dart Big M Block
10.2" Deck Height
custom je flat top Pistons
Eagle 4340 Forged Steel Crank dbl key way crank
4.750" Stroke
EAGLE 4340 H BEAM 6.700" Rods l19 bolts
KING ALECULAR PRO RACE Bearings
MAHLE Rings
moroso blue printed oIl pump
dooley 10 quat oil pan with windage try and trap door
choice of custom grind cams
one is a teage spec comp cam
the other is a marine kinetics custom grind
both are hydraulic rollers
with comp .200" taller hydraulic roller lifters
comp roller rockers
comp pushrods
DART 360 heads cnc ported and hand finished by Jon kaase
inconnel exhaust valves
stainless intake valves
5 angle valve job
cometic head and intake gaskets.
dart intake port matched to the heads with a 2" spacer tig welded(looks very nice)
1295 pro systems HOLLEY Dominator
ATI super damper
msd billet distributor
msd 6m2
cmi split top headers
all plumbing is steel braided and all fittings are aeroquip
huge oil cooler
everything on the motor is either powder coated, painted or polished. all arp fasteners.
the motor has 24 hours on it and is very reliable and docile around the dock. motor holds 65 psi oil pressure hot.
will sell ready to drop in and run for $16,500 obo with all accessories or $14,500 with everything less headers.
Thanks, Eric 678- 895-1148
I may trade for a blower motor.
monsterugglan 05-03-2011 04:15 AM
Hi Eric.
can you give me some pics?
[email protected]
