Hynautic Helm Pump
Would this be for a single ram (single engine) or twins? What would be required in addition to this helm pump to convert a boat that has "hynautic" (cable to transom, then hydraulic assist) to full hydraulic?
You would need external rams, Pressure Reservoir, relief valve or a Hynautic Reservalve that combines both. You can find them on ebay or I have seen a couple in the OSO swap.
http://teleflex.ru/upload/files/cata...d-Hynautic.pdf |
So if the boat already has external rams fed by the power steering pump, would you eliminate the power steering pump in a full hydraulic system? In other words, you turn the drives by hydraulic pressure without using a mechanical pump to assist you?
Sorry for the dumb questions. |
Originally Posted by dba900
(Post 3356502)
Ttt
TTT
offers? |
is the h-21 pump still available from rookie? Thks!
Yes, pretty sure it is still sitting out at my shop.
