Stocker stuff - starter, oil systems, etc
1 Attachment(s)
Trying to clear out some space in the garage. Most of this is stock, used stuff. Some of it is a little beat but I will be be honest in my description.
Not sure the interest level so let me know what you are interested in rather than list everything... |
What is the prop and how much for the cross over?
Prop is 30p bravo1, satin finish. Perfect shape.
Crossover appears to be cut (no bead or "lip" at the hose end). Still useable as is or add a quick bead before you install. How's $30 shipped? Probably over 100 new. |
Be great if someone just made me an offer on the whole lot :drink:
I will give you 30 shipped for the crossover all day!
Originally Posted by fantastixvoyage
(Post 3374933)
How much do you need to get for it all
crossover and the steering pump/bracket sold pending payment
One bracket, alt and eng harness potentially sold as well
Full package is as follows (some things already called pending payment)
1-Aluminum intake with bronze inserts, clean $75 2-Starters (non-matching) $50ea 2-Alternators - nice matched set $75ea (Pending) 4-Oil Adapters $25ea (3 pending) 2-Crank pullies (3rib) $25ea 1-ps pulley $20 1-stock mounts (eng side) $20 1-circulating pump, good shape $50 4-eng harnesses $50ea 1-small cooler $50ea 1-oil filter mount $50 SOLD 1-crossover $30 SOLD 1-ps pump&bracket 100 1-30p bravo1 $300obo Damaged: One eng/ps cooler - dented up but worked fine when pulled $50 One oil filter head mount - one mount tab partially broke off $20 (pending) Make me an offer on what's left and you will also have first shot on anyone that backs out. |
Hi Neal Tom here, how are things going , the oil filter mount ? size? what kind head mount? I will be home this weekend and it is high on my list of things to do to see you for the other parts . I liked to know about these filter mounts you have. TOM
Hey Tom - yep your mounts are still here waiting on ya! Filter mounts are just the stockers that bolt to the rear of the port side head and hold the filter horizontal off the head. Pretty typical setup. Held on by 3 bolts but one has half the bolt hole broken off, simple fix tho. Let me know if its something that works for ya.
What is the intake off of? Rectangle port or oval? Q-jet flange or Holley?
Thanks! |
Payment sent for the crossover....thanks!!!
Intakes a square port. Has larger secondaries, not real familiar with the stocker stuff. Nice intake, freshwater only. Cheap too lol
Crossover is already in the truck. Be going out tomorrow. |
(Post 3375380)
Thanks quadrajet it is then. Figured it might be for a spreadbore holley. I'm sure there are adapters if you'd like to run a holley.
oil filter bracket
I'll take one oil filter mount/bracket if not sold. Can pay pal.
Harvey 252-339-4560 |
Hello Harvey, no one's gotten back to me for sure so its yours. Tried to do the money order for the TRS gimabl at the post office @ lunch be it was packed. Can I just paypal you the $ (minus the mount cost)? Add $5 for ship, $55 total.
2 Attachment(s)
more pics
Email sent.
Thanks |
Email returned.
Oil filter bracket
May be dumb question but does the filter bracket have the head on it to screw the oil filter on and to install the two oil lines from the remote on the bottom of the block?
I had a issue with pay pal last year. Someone got into my account and charged away on my card. Paypal took care of everything, but I had to get new credit card, open new bank account. I never updated my bank account info with them. I only use my credit card to purchase thru them. So your paypal can't get into my account. That's why I prefer money order. Do you want to deduct the fifty dollars are do you want paypal? thanks Harvey |
No problem on the money order, I'll deduct $55 from what I owe ya and pick up any additional shipping charges.
hi Neal I am looking for at least 1 oil filter mount for my project mine broke off to bad to be fixed so i will take them if that is ok and if you want i will send you some money too...LOL TOM
Shipped a few things out today figured I'd bump the ad...
1-Aluminum intake with bronze inserts, clean $75 2-Starters (non-matching) $50ea 2-Crank pullies (3rib) $25ea 1-ps pulley $20 1-stock mounts (eng side) $20 1-circulating pump, good shape $50 4-eng harnesses $50ea 1-small cooler $50ea 1-ps pump&bracket 100 1-30p bravo1 $300obo Damaged: One eng/ps cooler - dented up but worked fine when pulled $50 2-Alternators -SOLD 4-Oil Adapters -SOLD 1-oil filter mount SOLD 1-crossover SOLD One oil filter head mount - one mount tab partially broke off SOLD |
| All times are GMT -5. The time now is 08:36 AM. |
