Konrad Outdrives
Nice set of Konrad 520 Outdrives will get some pic asap Bolt on replacement drives for TRS & TR drives!
No more converting to Bravo, filling the transom hole & moving the motor. The Konrad 520 has been engineered with hard work in mind and has a number of benefits that set it apart from the other stern drives on the market: Oversized bearings Thicker walled casings One piece propeller shaft Continuous oil circulation for cool operation No corrosive exhaust through drive Precision machined super alloy gears THESE ARE BOLT ON REPLACEMENT Drives , transom plate & gimbal with trim cylinders and pumps included $ make me some offers |
ttt
no body?
Just thought I'd chime in here and shed a little light on this post as I have been getting a fair amount of calls concerning used military drives. The Konrad 520 is a fantastic drive, built for diesel applications but I'd like to make it clear, the 520 is NOT a direct replacement for the TRS.
The 520 can be retrofitted for a TR application if the upper input shaft is swapped out to accomodate the existing transmission. (the 520 shaft is too short for these applications and could either be a male or female spline) It is most likely the gear ratio will be incorrect also as the majority of 520 units are 1.79:1 TR applications are 2:1 The main differences between the 520 and 540PRS (Performance Replacement System for TRS) is the lower gear case and upper input shaft. The 520 is built for heavier craft and utilizes a much deeper gear case with the ability to run 20" diameter props. A TRS application requires a special upper input shaft to accomodate the long TRS trans tail stock. A standard 520/540 shaft wiould be too short for this application. The Konrad 540 runs a much shorter lower gear case (almost 2" shorter than ther TRS) with a max prop dia up to 16" We can built just about any gear ratio but the majority of 540PRS units are 1.51:1 ratio. Hope this info is useful and feel free to give me a shout for more info. Kurt from Konrad 715-410-0735 |
Originally Posted by Biggus
(Post 3396230)
| All times are GMT -5. The time now is 03:52 AM. |
