-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Low Hour Drive Plate/Drive Couplers (https://www.offshoreonly.com/forums/swap-shop/258336-low-hour-drive-plate-drive-couplers.html)
Powerquest230 07-18-2011 07:39 PM
I'm listing these drive plates/drive couplers for my father. I believe the Merc part is #862975A1. Merc list is $663, Bam's price $585, looking for $200 each plus shipping.
Thanks,
Rick
Here's Pop's description and pictures-
I purchased two ZF630 transmissions from an insurance salvage fire-damaged boat that had approx 165 hours showing. The fire damage did not include the engine room. I've used the transmissions for two trips to the far Bahamas islands and
are totally happy with them and have had zero problems. The drive plates are fully functional and in good condition.
The drive plates were not compatible with my diesel engines and had to buy different ones. These have been in my garage for two years and I'm tired of looking at them. They are in excellent condition with the exception of minor rust from the Florida humidity in my garage. The rust can be cleaned up if it bothers you but will not affect the drive plate performance if you leave it. They have been sprayed with WD40. Works with several big block engines not just MercCruiser and several transmissions, including: MIE 350 MAG; 454 MAG HORIZON; 7.4L MPI; 8.2L MPI. But do your homework to insure compatibility. Spline has 26 teeth. Check for info- http://www.halemarine.com/index.php?...oducts_id=2480
http://i847.photobucket.com/albums/a..._sales_005.jpg
http://i847.photobucket.com/albums/a..._sales_006.jpg
http://i847.photobucket.com/albums/a..._sales_003.jpg
Powerquest230 07-19-2011 07:33 PM
These have steel splines not aluminum....
