-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   525 hp BBC, 50 hours (https://www.offshoreonly.com/forums/swap-shop/260921-525-hp-bbc-50-hours.html)
endeavour32 08-23-2011 05:02 PM
Below are the details on the engine I'm selling I'm asking $6000. I went the route of using a 427 crank on this engine due to it having a flatter torque curve than say a 496. This also allows the engine to run at high rpms for a long time due to the short stroke. The shorter stroke also keeps torque in check, this engine should be around 500-550 ft lbs of torque which is easier on the drive than a similar 496 higher torque engine. I had this in my Formula 242 and depending on the day it would give me a top speed of 66-69 MPH with a stock Mirage Plus prop and pop it out of the hole instantly. The only reason why I'm selling this is that I bought a Formula 292 and am selling the 242. I've got around $10,000 into this engine and I feel its easier to sell the engine out of the boat vs increasing the price of the boat. If you have any questions please let me know PM or Phone 847-754-0335.
I'm asking $6000 for the engine which is compete minus oil cooling system and exhaust. All engine work was done by Dave at Wesco Racing and all consulting on the engine was done with Bob Mandera of Marine Kinetics.
440 Cubic Inch BBC 525 hp @ 6000 rpms
Block-
Decked
Align Honed
Bored .060 over
Steam holes drilled
Bore notched
Rotating assembly:
GM Forged Crank, NOS 3.76 Stroke
Eagle H Beam Rods- Resized at Wesco
SRP Forged Domed Pistons
ATI Super Damper
Valve Train:
AFR 265 Oval Port Heads CNC Chambers, inconel Exhaust Valves
Morel Roller Lifters
Scorpion Endurance Marine Rockers
Marine Kinetics Roller Cam
234/240 .63/.61
Fuel System:
Weiand Stealth Intake
Pro Systems HP Holley, 830 CFM
Holley Marine Fuel Pump
MISC:
Mercruiser Thunderbolt distributor
Gil Flame Arrestor
Gil 10 Qt Oil Pan and pick up
Oil valley Screen kit
Mellings 10778C oil pump
endeavour32 08-24-2011 08:06 PM
ttt
jeffswav 08-24-2011 09:05 PM
How did you like those heads?
endeavour32 08-24-2011 09:34 PM
I love the AFR's. They are truly impressive, especially when you look at the flow #'s and runner size. If you're looking at a set of heads I would seriously recommend these!
endeavour32 09-20-2011 08:55 AM
open to offers this is a very nice engine.
endeavour32 11-17-2011 03:08 PM
bump
gary20099formula 11-18-2011 06:58 AM
picks pls
endeavour32 11-18-2011 08:57 AM
3 Attachment(s)
Here are a couple of pictures of the engine from last summer. I just pulled the engine and can get some more pictures if you want them. I also have a picture of my 242 running at WTO with this engine. It take a lot of power to get this boat to ride this far out of the water.
endeavour32 12-02-2011 08:49 AM
Sold!
