Complete running gear. SSM3&468
468 Aluminum headed BBC
Billett Eagle crank, Crower billett rods, Weisco Pistons, Edelbrock RPM heads, RPM intake, .750 solid roller comp marine cam, crower lifters, Jessel Belt drive, MSd distributor, Canton 12qt Marine Pan, All ARP, This is complete from carb to pan with fresh sea pump and alternator. Just add power and gas and go. 650-700hp Switching to outboards so you get everything. I am sure I am leaving somethings out. 20 min break in time on this motor. Only run time on engine stand, Never in boat since freshened. $5500 Speedmaster 3 with sportsmaster lower. lots of extras, props, gaskets, tools, manuals, other things. Drive, transom (fresh water only) trans, bell housing, coupler. Every thing to completely install a speedmaster except steering. $3500 Complete package of running gear. I will make someone a great deal to come take the whole package. $8000 from prop to crank pully. IM me for details Thanks OSO |
Possible trade for a set of outboards...
Also available, an opposite rotation SSM3 to make a set.
3 or 3A?
Just a 3 but it has a different lower.
Drive is now spoken for. Someone ring $4500 and take this motor....
Drive is now spoken for. Someone bring $4500 and take this motor....
What is the compression ratio, what carb?
p
What size props do you have?
The motor is 9.7:1 and it has a Holley mairine 900cfm. If the guy takes the drive he will get all the props.
| All times are GMT -5. The time now is 03:54 PM. |
