Dart Intake for a SBC
Single-plane, high-rise intakes designed to produce maximum power at higher rpm. Dart single plane small block manifolds are designed for standard port location 23 degree cylinder heads. Carburetor pads are specifically designed for 4150 & 4500 carbs. Extended runner dividers equalize port length and are radiused to equalize cylinder-to cylinder fuel distribution. Optimized runner cross-sectional area maintains high mixture velocity for maximum torque. Angled runners turn the airfuel mixture smoothly from carburetor to ports. Dual distributor hold-downs simplify timing adjustments. Manifold flanges are scalloped to clear center water outlets, and bosses for rear coolant lines are provided. Raised water cross-over and air gap insulate the intake charge from engine heat. Integral bosses for nitrous injectors.
We used this intake for dyno only, never run in the car. New sells for $433.09 plus tax and shipping. This is a nice clean unit. Call Brock @ 502 four six 0-1312 Part Number for this item is 42411000 @ darts website for a picture. |
| All times are GMT -5. The time now is 09:34 PM. |
