Two Mk IV Stroker BBC 496's- Short or Long
(2) GM Mk IV 496 Engines 9.800 Deck Ht.
Blocks Sonic Checked then Professionally Machined to spec. Callies Compstar Crankshafts Oliver Billet Steel Con Rods JE Forged Flat Pistons Speed Pro/Hastings/M-77 H-series Rings & Bearings New Canton Pro Series (18-364) 10 Qt. T-Baffled Oil Pans Internally Balanced, assembled by Victory Engines HEADS: (2) pairs of fresh GM 990 Steel Heads OR (2) pairs of Edelbrock Proprietary Ported Aluminum Heads Flow and Match Ported, Bronze Guides, APR Pro Series Studs (305cc Intake Runners) Severe Duty SS Intake Valves and Inconel Exhausts Shortblocks are $6,200 ea. Longblocks are $6,900 ea. with Iron Heads $7,600 ea. with Aluminum Heads *Can Supply Crane Hyd. Roller Cams (Recommend Dual Pattern 741's with above Heads) at cost or contact RMBuilder. Follow Link below for Pic's: http://www.flickr.com/photos/motorbi...7628716763857/ |
ttt Anyone?
ttt
ttt
these are really nice short blocks...
ttt
what kind of power will you generate from theese packages
Originally Posted by ROB FREEMAN
(Post 3596102)
ttt
ttt
| All times are GMT -5. The time now is 01:38 AM. |
