drive special tools
I have a lot of special drive tools for OMC, Volvo, Yamaha and a few Bravo as well as a couple of Sea Doo tools. these all look to be in good shape and came out of a closed boat dealership. I dont build drives so if anyone is looking for some below is the list. I have listed what they are for if I know and the ones with just a number I havent figured out so if you know I would appreciate the help.
Bravo: 91-865114 pinion height tool-may be for alpha $85 91-91947 bearing carrier retainer wrench 40-70hp $35 91-99222 gearcase cover removal tool 3.9-9.8hp $40 OMC/Volvo 3854864 pinion threadnut holder $25 884168 Cobra lower gear bearing press tool $35 3850604 hook spanner $85 3850601 hook spanner $30 3850598 spine socket $30 3850701 Cobra upper/lower gear shimming tool $25 884263 Cobra upper bearing tool $40 3850599 Cobra pinion shimming tool $30 884161 prop bearing/lower intermediate shaft remover $90 884938 gear bearing sleave $35 3850606 upper gear/bearing remover/installer $30 3849652 ? threaded tool Yamaha YB-06B19 ?? YB-38226 drive gear & spacer/reverse gear shim $40 YB-34447 ring nut wrench YB-06175-1A trim cylinder spanner $30 YB-06B00 ??? YB-38222 drive gear shimming gauge $35 YB-38221 drive gear shimming gauge $40 YB-34446 gear height gauge Sea-Doo 529035956 sea doo impeller tool $25 529-036-026 to push ring back to remove diveshaft $100 I have pictures of each and may have a couple others if you are looking for something. open to offers on any or all. steve schmidt [email protected] |
sea doo impeller tool is sold.
thanks |
the following are sold
YB-34447 yamaha tool and 91-91947 mercury tool thanks |
| All times are GMT -5. The time now is 10:21 PM. |
