Fresh 468's
Two 468's. Recent 2-bolt blocks, bored .060. TRW Forged Pistons, .090 dome. Eagle H-Beam Rods. GM steel cranks. ARP Main Studs. Merlin oval port iron heads. H-series rod and main bearings. New Comp Cams 11-316-4 flat tappet cams on pro core. New Comp Cams timing chain, lifters, springs. Magnum pushrods. Ferrea valves. Mercruiser AL pan.
Performer RPM manifolds, Holley marine 750s just rebuilt. Stainless crossovers, TB ignition mounted on CP Performance brackets which also mount the solenoid, breaker, and cannon plug. New Holley marine fuel pumps. All new Aeroquip oil plumbing. Newly rebuilt alternators, sea pumps. Engines are complete except exhaust and oil coolers. Engine are at Central Florida Machine and Speed now for all machine work and assembly. Still time to pick certain parts and or have painted in the color of your choice. Asking $11,000 for the pair, assembled. Will separate. Thanks, Randy |
ttt. Hp should be in 420hp/420tq range based on cam choice. Can dyno following assembly. Thanks, Randy
| All times are GMT -5. The time now is 08:50 AM. |
